Dde_B
7 years agoWhy won't PLL Reconfig IP allow access to cascaded tap?
So, I have created a PLL with a 50MHz clk in. From there I generate two clocks. C0 = 100MHz, and C1 is 100KHz. The PLL achieves these values by having an M = 12, N=1 and a C0 counter of 6 for t...
SreekumarR_G_Intel
7 years agoHello David,
Can you let me know which device you are using ? As Alex mentioned already, I also wonder how tool let you allow to change to 100KHz . I just tried with Arria 10 device. Tool is not letting me allow less than 1MHZ. can you please clarify ?
Thank you ,
Sree
Dde_B
7 years agoHere is the config wizard stating that 0.1MHz is achievable: I have synthesized and implemeted this on the HW.
