JLIU45
7 years agoWhy is there no output in PLL simulation?
I instantiated a PLL in my design, refclk is 50MHz, 3 output clocks are 500MHz, 50MHz, 25MHz respectivily, and I enalbe dynamic phase shift option. But only the output 500MHz is valid, the other two ...
Vicky1
7 years agoHi,
Please follow the steps as mentioned in below application notes,
https://www.intel.com/content/www/us/en/programmable/documentation/mcn1424769382940.html#mcn1424940703121
please let me know, how it works for you.
Vicky
JLIU45
7 years agoHi, Vicky:
I think I've solved the problem, just because this PLL needs a POR, however, this operation is not necessary for other PLLs, anyway I can run the simulation, thank you very much.
BR
Liu Jianjun
