JLIU45
7 years agoWhy is there no output in PLL simulation?
I instantiated a PLL in my design, refclk is 50MHz, 3 output clocks are 500MHz, 50MHz, 25MHz respectivily, and I enalbe dynamic phase shift option. But only the output 500MHz is valid, the other two ...
Vicky1
7 years agoHi,
Could you please refer the below reference design for Dynamic phase shift with Intel PLL IP core
Please let me know, how it works to you.
Vicky
JLIU45
7 years agoHi, Vicky:
thanks for your reply, I checked the design and understand that.
However, my confusing is that the simulation cannot work, and I used the auto-generated simulation testbench. below is my simulation waveform, FYI, only outclk_0(500MHz) is valid, the other two is x.
BR
Liu Jianjun
