SThom66
6 years agoWhy does the Avalon-MM bridge add 5 bits of address (33 total) when connecting to a DDR3 memory controller that only needs 28 bits?
I have a Platform Designer design with two DDR3 memory controllers. They both require 28-bits address on the Avalon bus. I want them to look like contiguous memory. I want to connect an Avalon-MM Pip...
NurAida_A_Intel
6 years agoHi Sir,
Welcome to Intel Community.
As I can see the data width from DDR3 controllers and bridge is difference.
You can change the data width to be the same, and then address unit changed to "words".
Meaning, change the bridge data width from 32 bits to 256bits. Then, change the address unit to "words".
Aida
