leonqin_2025's avatar
leonqin_2025
1 year ago
Why AXI MCDMA IP output axi-stream with Spares TKeep and borken TData?
as described in datasheet,"The sparse tkeep is not allowed."
but,I got the wave by signaltap:
why?
  • Hi,
    The "sparse tkeep" means a pattern like 8'b10101010.
    A tkeep like 8'b00001111 is considered contiguous.
    Rong
    • leonqin_2025's avatar
      leonqin_2025
      Thanks for your reply!
      but in UG-817911,"The invalid bytes are allowed only during
      h2d_axi_st_tlast cycle" means that it allowed ONLY at last cycle?
  • Since there are several modes in MCDMA IP, could you please send me your mcdma.ip and let me know the Quartus version you're using?
    I'll check this from my end.
    Rong
      • RongY_altera's avatar
        RongY_altera
        You can paste a download link here.  This is so far the way to share a file.
        Rong
        RongY_altera
        According to the spec, TKeep should be all ones for all non-TLAST cycles. The observed sparse TKeep before TLast violates this requirement.
        Please re-check your test since this behavior could be caused by earlier incomplete transactions or test setup issues, and should be further investigated.
        Rong
