Why are signals rx_is_locktodata and rx_is_locktoref always at 0?
- 5 years ago
As I understand it, you observe some issue with the C10GX XCVR where the CDR does not achieve lock-to-data mode. For your information, the CDR refclk and the TX PLL need to be sourced directly from free-running oscillators on-board through dedicated XCVR reference clock pins.
I have attached a simple A10 Native PHY design previous from wiki for your reference. You can refer to the basic block and connection required to see if it is helpful.
- Длаза5 years ago
Thanks for the project for Arria10. I loaded to my FPGA and he is worked. I also connected rx_cdr_refclk to pin ATX:refclk, but its not worked.
Thank you.
