alinave
6 years agoWhich Memory Timing information should be used in DDR4 EMIF IP for Stratix 10 if using a higher speed grade memory device at a lower speed - the higher speed grade or the lower speed grade?
Hi, I am setting up the DDR4 controller IP for a device which has a speed bin of 3200 MT/s. However, I would be using that device only for 2400 MT/s. While entering the timing parameters from the de...
BoonT_Intel
6 years agoin this case, my practice is to use the larger latency value as this loosen the requirement but it gives additional latency to the traffic.
If you have the memory support contact, you can check with them see if they got better explanation on this. Hope you can share with us if you get the answer from them. Thanks 😉
- alinave6 years ago
Hi BoonT_Intel,
Thanks a lot for your input. I'll get back to this thread soon. :)
Naved
- BoonT_Intel6 years ago
Hi Naved,
Are you able to contact Memory support?
