Where to download XCVR IP Core for Cyclone 10 GX and updated design example?
As I understand it, you have some inquiries related to an example design. To ensure we are on the same page, would you mind to further elaborate on which specific example design that you are referring to? It would be great if you can share with me the download link or weblink to the design as well.
Based on my understanding, generally an example design (not IP generated) is created and validated based on specific Quartus version. To ensure compatibility, it is recommended to use the same version to work with it.
Chee Pin
You are correct. I realize the XCVR IP Transceiver PHY is available in the Platform Designer library but I am using a design example tailored for the Cyclone 10 GX Dev Board.
Here is the link:
I am using the 17.1.2 version off Quartus, do I really need to downgrade to the 17.1.1 version for this to work?
I am leverage off this design to do some testing on the Dev board but I am running into the <sw_library.iipx> and <hw_library.iipx> issues.
-Kyle
