JLee25
Contributor
7 years agoWhere is SDI Audio Embedder in Q 18.0
I am looking for SDI audio embedder IP in Quartus Prime Pro Edition 18.0?
Can you tel me how to find it ?
I am not able to find it in IP Catalog.
Thank you!
BRs,
Johnson
- CheepinC_altera
Hi Johnson, As I understand it, you have some inquiries related to SDI audio IP. If I understand it correctly you are using 10 series devices. For your information, the SDI audio IP is no longer supported in 10 series devices. This is why it is not available in the Quartus Prime Pro IP catalog. Sorry for the inconvenience.- JLee25
Contributor
Hi CP,
Thank you for the prompt reply.
Johnson
- CheepinC_altera
Hi Johnson, Thanks for your update. Sorry for the inconvenience. I will set this case to closed. Thank you.
