Where could I find Windows driver for Agilex F series P-tile and F-tile PCIe endpoints?
Thanks for reaching out, Normally the driver is included in the design example where you can get in the FPGA design store.
You may try to run the design example and check if it is running well.
WeiChuan_C_Intel
- chunxi_yu4 years ago
Hi WeiChuan,
Thanks for the information!
I checked FPGA Design Store | Intel and find that Agilex only has 7 examples there without PCI related examples.
So I just used Quartus to generate the PCIe AVST and MCDMA example design. There is a software directory under both design root. But they seems like linux drivers.
I don't see any option I could modify that looked like Linux/Windows when generating the example design. Is it because my Quartus is running under Linux and it is a linux version? Do I have to install a Windows version Quartus and generate the example design to get a Windows driver or is there only Linux driver for Quartus generated designs?
Chunxi
- Wincent_Altera4 years ago
Hi Chunxi,
There is specific driver needs to be install.
You can try to install Windows version Quartus and generate the design example.
If you facing any problem/error, feel free to get back to us anytime
WeiChuan_C_Intel
Hi Chunxi,
There is no specific driver needs to be install.
WeiChuan_C_Intel
