kdewe
7 years agowhen i try Test Pattern II->Frame BufferII->Clocked Video Output,but it doesn't show the correct image.
This is part of my system. But
CheepinC_altera
7 years agoHi,
As I understand it, you observe some issue with you VIP link. To ensure we are on the page, just would like to check with you on the following:
1. What is the device that you are using?
2. What is the Quartus version that you are using?
3. Are you observing issue in hardware/simulation or both?
4. To facilitate further debugging, it would be great to create a simple test design with Test Pattern II->Frame BufferII->Clocked Video Output, then perform Modelsim simulation to see if similar issue observed? This would be helpful to narrow down any functional related issue.
Chee Pin
