what's the main concern to set or not set associated clk and reset
- 6 years ago
The Component Editor knows nothing about the functionality of your custom component. As such, you have to specify the standard interface signal roles of your top-level ports (clock, reset, etc.) and the associated clock and reset for each standard interface (Avalon, AXI).
For the example you mention, it sounds like those signals are making up a conduit instead of a standard interface, confirmed by your screen capture. As such, associated clock and reset are not required for this type of interface. I think you may see warnings if you use the component in a system, but they're just warnings, not errors. You can set associated clock and reset since the Component Editor gives you the option, but I don't think it will cause any issues if you don't.
#iwork4intel
Hi, Xiaoqiang
The standard Avalon interface will not include the clock and reset. And therefore you need to add the clock and reset. The clock and reset allow you to connect to other external clock and reset blocks in Platform Designer.
If you have no more question, can I close the case ?
Eric
- XQSHEN6 years ago
Thanks, I am ok to close it.
