CSmit14
7 years agoWhat VIP IP does 2 color plane to 3 plane mapping? Chroma Reamplier and CVO
I am using the Intel FPGA SDI-II core to interface with a MIPI-TX IP from an Intel FPGA partner in the following format: SDI-II-RX ----------------> MIPI-TX [8 bit per color, ...
CheepinC_altera
7 years agoHi,
Just would like to check with you if you have filed a IPS case on this? If yes, for your information, I have responded in the IPS and we shall continue to follow up with you in the IPS case.
Thank you.
