MSimp5
7 years agoWhat is the best way for a NIOS II to communicate with the DDR3 SDRAM on the Cyclone 10 GX dev kit?
I am currently trying to build a project where a NIOS II needs to communicate with the SDRAM on the Cyclone 10 GX Dev Kit and was wondering what the best way of doing this is. I have tried connectin...
sstrell
7 years ago320? That's a strange width. I'm pretty sure you need a power of 2 or power of 2 plus bits for ECC (if you're using it).
Most dev kits include an example design for the memory that may include a Nios processor or you can generate an example design from the EMIF IP Parameter Editor and connect a Nios to it..
