matif
6 years agowhat is "fifo_out_csr_address" input in Avalon FIFO Memory ip?
SyafieqS
6 years agoHI,
Is there any possible screenshot of the system design that show that signal for better investigation
matif
6 years agoHere is the qsys system picture attached. and the module instantiation of qsys system. You can see (fifo_0_out_csr_address) and (fifo_1_in_csr_address). Just wana know what are these ports? and these are input ports.
module soc_system (
input wire [2:0] fifo_1_in_csr_address, // fifo_1_in_csr.address
input wire [2:0] fifo_0_out_csr_address, // fifo_0_out_csr.address
input wire clk_clk, // clk.clk
output wire [15:0] fifo_0_out_readdata, // fifo_0_out.readdata
input wire fifo_0_out_read, // .read
input wire fifo_0_out_csr_read, // .read
input wire [31:0] fifo_0_out_csr_writedata, // .writedata
input wire fifo_0_out_csr_write, // .write
output wire [31:0] fifo_0_out_csr_readdata, // .readdata
input wire fifo_0_reset_out_reset_n, // fifo_0_reset_out.reset_n
input wire [15:0] fifo_1_in_writedata, // fifo_1_in.writedata
input wire fifo_1_in_write, // .write
input wire fifo_1_in_csr_read, // .read
input wire [31:0] fifo_1_in_csr_writedata, // .writedata
input wire fifo_1_in_csr_write, // .write
output wire [31:0] fifo_1_in_csr_readdata, // .readdata
input wire fifo_1_reset_in_reset_n, // fifo_1_reset_in.reset_n
inout wire hps_io_hps_io_sdio_inst_CMD, // hps_io.hps_io_sdio_inst_CMD
inout wire hps_io_hps_io_sdio_inst_D0, // .hps_io_sdio_inst_D0
inout wire hps_io_hps_io_sdio_inst_D1, // .hps_io_sdio_inst_D1
output wire hps_io_hps_io_sdio_inst_CLK, // .hps_io_sdio_inst_CLK
inout wire hps_io_hps_io_sdio_inst_D2, // .hps_io_sdio_inst_D2
inout wire hps_io_hps_io_sdio_inst_D3, // .hps_io_sdio_inst_D3
inout wire hps_io_hps_io_usb1_inst_D0, // .hps_io_usb1_inst_D0
inout wire hps_io_hps_io_usb1_inst_D1, // .hps_io_usb1_inst_D1
inout wire hps_io_hps_io_usb1_inst_D2, // .hps_io_usb1_inst_D2
inout wire hps_io_hps_io_usb1_inst_D3, // .hps_io_usb1_inst_D3
inout wire hps_io_hps_io_usb1_inst_D4, // .hps_io_usb1_inst_D4
inout wire hps_io_hps_io_usb1_inst_D5, // .hps_io_usb1_inst_D5
inout wire hps_io_hps_io_usb1_inst_D6, // .hps_io_usb1_inst_D6
inout wire hps_io_hps_io_usb1_inst_D7, // .hps_io_usb1_inst_D7
input wire hps_io_hps_io_usb1_inst_CLK, // .hps_io_usb1_inst_CLK
output wire hps_io_hps_io_usb1_inst_STP, // .hps_io_usb1_inst_STP
input wire hps_io_hps_io_usb1_inst_DIR, // .hps_io_usb1_inst_DIR
input wire hps_io_hps_io_usb1_inst_NXT, // .hps_io_usb1_inst_NXT
input wire hps_io_hps_io_uart0_inst_RX, // .hps_io_uart0_inst_RX
output wire hps_io_hps_io_uart0_inst_TX, // .hps_io_uart0_inst_TX
output wire [14:0] memory_mem_a, // memory.mem_a
output wire [2:0] memory_mem_ba, // .mem_ba
output wire memory_mem_ck, // .mem_ck
output wire memory_mem_ck_n, // .mem_ck_n
output wire memory_mem_cke, // .mem_cke
output wire memory_mem_cs_n, // .mem_cs_n
output wire memory_mem_ras_n, // .mem_ras_n
output wire memory_mem_cas_n, // .mem_cas_n
output wire memory_mem_we_n, // .mem_we_n
output wire memory_mem_reset_n, // .mem_reset_n
inout wire [31:0] memory_mem_dq, // .mem_dq
inout wire [3:0] memory_mem_dqs, // .mem_dqs
inout wire [3:0] memory_mem_dqs_n, // .mem_dqs_n
output wire memory_mem_odt, // .mem_odt
output wire [3:0] memory_mem_dm, // .mem_dm
input wire memory_oct_rzqin, // .oct_rzqin
input wire reset_reset_n // reset.reset_n
