AThom47
6 years agoWhat does the arbitration look like for multiple masters to a single slave on an Avalon MM bus?
Hi, I am trying to find out what the arbitration looks like when there are several masters accessing a single slave on an Avalon MM bus. I found some old information online (AN184) that describes th...
KennyT_altera
6 years agoFor question 1,3,4, you can refer to
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-platform-designer.pdf page 136 arbitration.
For question 2,
If the master is starting a burst access indicated by the burstcount signal of more than 1, does the master keep access until the burst is done before the next master gets access?
Yes, basically, they should be waitrequest/valid when u assert the burst. you can refer to the link above page 101.
