vikas194
3 years agoWe have differential input, How can this be given to ALT LVDS RX IP
we are designing a LVDS receiver on Cyclone 10 LP which receives differential data from TI AWR6843. How do we connect differential input to cyclone 10 LP device since ALT LVDS RX IP is not c...
FvM
3 years agoHello,
ALT LVDS IP is compatible with any IO standard that you connect to the input. For LVDS input, choose a differential pair and assign the positive pin to the receiver input signal. Also select LVDS IO standard for the signal, requires that the respective bank is powered by 2.5V. Negative pin is added automatically by the fitter.
Frank
