XQSHEN
6 years agoWarnings when fitter max10 + NIOS + UNIPHY
Below warning are generated when fitter 10M16DCU324I7G Nios and Uniphy IP was used for DDR2 RAM. What should I do? Warning (14285): Synthesized away the following RAM node(s): Warning (14320):...
EricMunYew_C_Intel
6 years agoHi, Xiaoqiang
Warning (169064): Following 2 pins have no output enable or a GND or VCC output enable - later changes to this connectivity may change fitting results
Info (169065): Pin memory_mem_ck[0] has a permanently enabled output enable
Info (169065): Pin memory_mem_ck_n[0] has a permanently enabled output enable
Pin memory_mem_ck[0] and pin memory_mem_ck_n[0] are either have no output enable, or they are VCC and GND enable.
If you enable them later, it will change your fitting result. You may want to add an output enable that is not GND/VCC to them.
Eric
