BHoey
8 years agoViterbi License Requirements
There are two Viterbi license types : IP-Viterbi/HS and IP-Viterbi/SS /HS is the parallel implementation. /SS is the hybrid We have the /HS licensed. When building a design with the core in it (...
Vicky1
7 years agoHi Steve,
Thanks for the details.
I tried to replicate the issue using given design files but I am not able to do so & reason is floating license.
here I don`t have option to use only IP-Viterbi/HS , for that I should have standstill license for IP-Viterbi/HS in that case I may replicate the issue.
I will try to check internally & get back to you.
Please have a look to the screenshots.
- with license
- without license
Vikas
