BHoey
8 years agoViterbi License Requirements
There are two Viterbi license types : IP-Viterbi/HS and IP-Viterbi/SS /HS is the parallel implementation. /SS is the hybrid We have the /HS licensed. When building a design with the core in it (...
SZack
7 years agoHi Vikas,
I am the local Altera-dedicated FAE at Arrow working with Brian. I was able to replicate the customer's problem when using 18.1 Pro. Make sure you disable your super license or at least comment out the Viterbi/SS core from your license file. Attached is a test archive you can use to try and re-create the problem.
Steve
