BHoey
8 years agoViterbi License Requirements
There are two Viterbi license types : IP-Viterbi/HS and IP-Viterbi/SS /HS is the parallel implementation. /SS is the hybrid We have the /HS licensed. When building a design with the core in it (...
Vicky1
8 years agoHi Brian,
"Warning(18395): "Low Speed Viterbi Decoder" does not support the Intel FPGA IP Evaluation Mode feature"
Can you check by disabling the evaluation mode?
Refer the "1.6 Disable Intel FPGA IP Evaluation Mode" from following link,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an320.pdf
"Warning(115005): Unlicensed IP: "Low Speed Viterbi Decoder(6AF7 0038)"
also check the license status,
Refer the "1.2 Viewing IP Core License Status " from above link.
Best Regards
Vikas Jathar
