ACoff2New Contributor7 years agoViterbi IP - BER estimate error number I am using the Viterbi decoder ip (altera_viterbi_ii) in a project. I am encoding a count variable using a convoluational encoder. I then passing this through the Viterbi decoder block. The data out...Show More
CheepinC_alteraRegular Contributor7 years agoHi, Just would like to follow up with you on this. Thank you.
Recent DiscussionsSysID TimestampCyclone 10 GX Transceiver Power-Up Calibration Time (~353 ms) Analysis RequestAVST FIFO and AVST Demultiplexer IP Simulation BehaviorUser controlled burst refreshF-tile ethernet hard ip in agilex7
