JHerz
7 years agoVIP Framebuffer locked rate support: Howto setup?
If locked framerate is enabled in the framebuffer IP core, locked framerate may be controlled through registers Input Frame Rate and Output Frame Rate. These registers have an impact on frame droppin...
JHerz
7 years agoHi dlim,
thanks for your quick response! I am working with Quartus version 16.1 - so I stick mainly to its documentation and this application example does not exist in this version.
I took a short look in 18.1 documentaion but did not look carefully enough.
Johannes
