16 years agoverilog- parameterized mux
For the life of me I cannot figure out how to generate a parameterized mux in verilog... I understand how to generate, say, a 4:1 MUX of "N" bits wide... But I am trying to generate an N:1 mux...
16 years agoEquivalent / alternative examples
1 - The one I already posted with a correction:module mux (#parameter WIDTH = 8,
# parameter CHANNELS = 4) (
input in_bus,
input sel,
output out
genvar ig;
wire input_array ;
assign out = input_array;
generate
for(ig=0; ig<CHANNELS; ig=ig+1) begin: array_assignments
assign input_array = in_bus;
end
endgenerate
//define the clogb2 function
function integer clogb2;
input depth;
integer i,result;
begin
for (i = 0; 2 ** i < depth; i = i + 1)
result = i + 1;
clogb2 = result;
end
endfunction
endmodule 2 - Similar to# 1 but without using the "Variable Vector Part Select" operator: module mux (#parameter WIDTH = 8,
input in_bus,
input sel,
output out
genvar ig;
wire input_array ;
generate
end
endgenerate
input depth;
integer i,result;
begin
result = i + 1;
clogb2 = result;
end
endfunction
endmodule 3 - Equivalent logic without using a generate statement. I don't recommend this because some simulators don't work well with the "reg" type declaration for the array. Again, you could rewrite this to not use the "+:" operator if you wish. module module mux (#parameter WIDTH = 8,
input in_bus,
input sel,
output out
integer i;
reg input_array ;
always @*
for(i=0; i<CHANNELS; i=i+1)
input depth;
integer i,result;
begin
result = i + 1;
clogb2 = result;
end
endfunction
endmodule
Jake
