JLee25
Contributor
6 years agoV Series Native Phy Simulation
Hi, I am using the CV Native Phy Manual Align BYTE Order Double Width as a template for my requirement. I modify the phy ip parameter and run the simulation. But looks like Word Aligner and Byte...
Deshi_Intel
6 years agoHI Johnson,
Pls give me sometime to review both the example design and your modified design.
Btw, byright you should be using "Cyclone V Native PHY with manual alignment and byte ordering in double width mode design example" that's closer to your design requirement but your attached design is the 8b10b example design instead ?
Have you try out and cross check with the double width example design without the 8b/10b ?
dlim
JLee25
Contributor
6 years agoHi Dlim,
Thanks for getting back.
Please forget the previous attachment project.
I am generating another one because I found an error when generating the native phy ip with device.
I will ask more questions later.
BRs,
Johnson
