JLee25
Contributor
6 years agoV Series Native Phy Simulation
Hi, I am using the CV Native Phy Manual Align BYTE Order Double Width as a template for my requirement. I modify the phy ip parameter and run the simulation. But looks like Word Aligner and Byte...
JLee25
Contributor
6 years agoHi Dlim,
Based on the reference project I received, I made some modifications to meet my requirement.
Data rate to 2.7Gb with 20-bit PMA/ PCS interface.
Then I started simulation and found the manual Word Aligner mode is not working properly.
I suppose the word aligner should align to 17C but no response as below.
Would you review and give me suggestions?
I attached here for your check.
Thank you!
BRs,
Johnson
