SPont2
6 years agoUsing the Low Latency 40-Gbps Ethernet Intel® Stratix® 10 IP Core with 4x10 GbE Breakout cables
I wonder if it is possible to use a breakout cable that splits a QSFP+ to 4 SFP+ with the Low Latency 40-Gbps Ethernet Intel® Stratix® 10 IP Core. There is some parameter/option to enable in the I...
SPont2
6 years agoDear dlim,
sorry for the late replay. I tested the solution you suggested with 4x10 and seems working.
Thank you for your support.
