SPont2
6 years agoUsing the Low Latency 40-Gbps Ethernet Intel® Stratix® 10 IP Core with 4x10 GbE Breakout cables
I wonder if it is possible to use a breakout cable that splits a QSFP+ to 4 SFP+ with the Low Latency 40-Gbps Ethernet Intel® Stratix® 10 IP Core. There is some parameter/option to enable in the I...
Deshi_Intel
6 years agoHi Salvatore,
Yup, you have a point. I looked further into 40G IP user guide but it didn't mention about separate control over each 10G channel.
I am sorry. Looks like I may had mislead you earlier.
I consulted internally further and the recommended design implementation is to use 4 separate Ethernet 10G IP instead of one single 40G IP.
After that, you can still connect these 4 transceiver channels from the 4 different 10G IP into one QSFP module that further connect with the breakout cable to 4 individual 10G ports.
dlim
