ASuba
7 years agoUsing Intel IPs into our custom IP design
Hello I am using Quartus Lite version for intel FPGA. I am in the process creating custom IP . Within the lower hierarchy I would like to use FIFO IP provided by Intel. How to instantiate this IP i...
ASuba
7 years agoHi KYeoh
I am creating a custom module .. This module will be further added as an ip in the larger SOC design(Created in QSYS, platform designer). Now I want to add in the custom module an IP(FIFO; ie DCFIFO WITH MIXED CLOCK) generated in from QUARTUS IP catalog(DCFIFO is not available in QSYS IP catalog). So for this what are the files needed while I manually add this IP to my custom module . I would like to add all the submodules of FIFO along with it and therefore where can I find them ?.
Hope you are clear with my question
best Regards,
Athira
