using DSPs in the FPGA as ALMs for standard FFT IP
you can try look for https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii51008.pdf if there dsp attribute.
also, if you look for 16-32, there are dsp balacing to help you auto convert the dsp to logic
- VenkateshSathar7 years ago
I looked in the PDF 16-32, that is telling about the option of DSP balancing when ALMs are not available how to use DSP blocks as slices, but my case is different right now for me whatever ALMs and DSPs block conusmption mentioned in FFT User guide are not matching with the current consumption.
As in the datasheet/user guide it is mentioned that DSP blocks will be consumed but in the actual scenario ALMs are getting consumed where I require ALMs for my other logic blocks to develop. So, I want the FFT IPs I added in my project I want DSP blocks for computation/multiplication logic to be consumed instead of ALMs.
My question is why that is not happening for the above synthesis settings i gave previously. To make it happen what to do?
