Jonnew
5 years agoUse of dedicated analog input and dual-purpose analog pins for digital signals on Max10
I have a MAX 10 design (part: 10M08SAM15317G) in which I'm attempting to use the MAX 10 ADC Hard IP Block to capture signals on the dedicated Analog Input (Pin ANAIN[1]) while preserving the the dual...
- 5 years ago
No, you cannot use the rest of the dual-purpose pins as GPIO pins if you are using the ADC, despite you are just using the ANAIN pins.
JonWay_altera
5 years agoNo, you cannot use the rest of the dual-purpose pins as GPIO pins if you are using the ADC, despite you are just using the ANAIN pins.
- Jonnew5 years ago
OK, that is definitive.
Can you point me to the documentation where this is specified? If not, I would suggest that the documentation is updated to make this clear if the ADC Hard block is used, all digital IO, including the MUXed, non-dedicated inputs are not available for digital IO.
Thank you for your help!
