vsath
7 years agousage of SGDMA IP for data transfer to and from DDR3
Hi, I want to develop a system with NIOS II Processor on Arria V of one of our custom boards for DDR3 memory transfers. where as there will be a sensor which will be giving around 128 bit data per...
VenkateshSathar
7 years agoyes.. I will look in that way also and tell you if anything I find.. meanwhile please review the project I have sent and if possible if you have the kit i mentioned you also run once and see the result please. Actually I already enable signal tap also in the project i gave. You can see that also once.
NurAida_A_Intel
7 years agoHi VSath1,
Just to let you know that we are still working on the design to isolate the root cause. I'll let you know the results once we have done.
NAli1
