Updating the symbol leading to .sof not working even though logically not changed anything due to library.
Hi AnandRS,
One good news..!
Actually, now things started working fine.
How is that I will tell you:
Our vendor gave the project in .zip files and .qar files.
I was using .zip files for project usage and updating my logic where as neglected .qar files completely.
Meanwhile, He messaged us to use only .qar project files, in that any files missing happens just use .zip to copy things from that and paste here.
After that, right now working on that .qar extracted project now. No problem, with update of symbol also.
Could able to add and do data transfer to second ddr also as I was mentioned in the start of this issue description.
Could able to change the project also.
So, You guys better tell if there is any solid reason for things getting failed when using .zip and library paths etc adding with that project and passing with .qar usage.
Thanks a lot for your co-operation, infact your inputs also helped a lot to us in getting clarified about the tool usage and other things. 😃
Venkatesh Sathar.
