GDagi1
6 years agoUnable to enable RX_TNA and TX_ENA bits (Triple-Speed Ethernet IP)
Hi all,
I'm working with the Triple-Speed Ethernet IP and currently am in the process of setting up the MAC register space. I am following the order found in 5.3.1 of the Triple-Speed Ethernet User...
- 6 years ago
I believe to have solved the issue. Through prior experience with Intel IP, I had thought to implement a counter to remain in the writing state, as it may take some time for this update to complete. I now see these bits go high. I could not find this explicitly stated within the Triple Speed IP User Guide.
Deshi_Intel
6 years agoHI,
It's good to know you have solved the issue.
One thing to take note is the step 2(E) in TSE user guide doc section 5.3.1.
- You need to wait for SW_RESET bit to clear (change from 1 to 0) before you assert TX_ENA and RX_ENA in step 2(F)
Aright, I am now setting this case to closure.
dlim
