SKon1
6 years agoTSE - PCS only internal loopback problem
Hello, I'm using the TSE core in a PCS only configuration on an Arria V FPGA. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf Data is being sent from my...
SengKok_L_Intel
6 years agoHi,
I can see the same behavior in simulation, and yes this is expected behavior. This behavior won't impact the functionality of the IP. For detailed info, you may refer to the following errata.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/fb162858.html
Regards -SK
