Konrad
6 years agoTripple Speed Ethernet (tse) Avalon-ST interface format
I am using the tse in small mac mode for a fixed 100M only connection. The project is in Quartus 16.
I am a bit confused as to how the avalon-ST interface works. I have read the avalon-ST user gui...
Deshi_Intel
6 years agoHi,
You are using unique way with EOP to chop of the packet instead of using mask bit or 8 bits transfer (not 32 bits). So, yup, it's recommended for you to test it out in simulation better.
For the Ethernet packet length control,
- Min length is 64 bytes (if enabled padding and actual packet transfer is less than 64 bytes, then TSE MAC will insert padding bytes)
- Max length is 1500
dlim
