CNiclaes
1 year agoTriple-Speed Ethernet IP on Cyclone V GX with IEEE 1588 support
Hello, I try to run the Triple Speed Ethernet MAC IP with IEEE 1588 support on a Cyclone V GX device. My configuration is: - Core Variation: "10/100/1000-Mbps MAC with 1000BASE-X/SGMII PCS" - Unc...
CNiclaes
1 year agoHello,
I'm not happy with your answer since it doesn't fit my question.
In the documentation it is very clear I've got to use the listed configurations, but the "10/100/1000-Mbps MAC with 1000BASE-X/SGMII PCS" choice means that you can use either 1000BASE-X (Single Speed PCS at 1000 Mbps) or SGMII (Multi Speed PCB with 10/100/1000 Mbps). I would like to use 1000BASE-X but for that I need to disable the SGMII bridge PCS option, which I can't do when I try to configure my IP. Why?
Christophe
