CNiclaes
1 year agoTriple-Speed Ethernet IP on Cyclone V GX with IEEE 1588 support
Hello, I try to run the Triple Speed Ethernet MAC IP with IEEE 1588 support on a Cyclone V GX device. My configuration is: - Core Variation: "10/100/1000-Mbps MAC with 1000BASE-X/SGMII PCS" - Unc...
paveetirrasrie_Altera
1 year agoHello,
Apologies for the delayed response.
The Triple-Speed Ethernet Intel FPGA IP supports the IEEE 1588v2 feature only in the following configurations:
• 10/100/1000-Mbps MAC with 1000BASE-X/SGMII PCS and embedded serial PMA without FIFO buffer in full-duplex mode
• 10/100/1000-Mbps MAC with 1000BASE-X/SGMII PCS and embedded LVDS I/O without FIFO buffer in full-duplex mode
• 10/100/1000-Mbps MAC without FIFO buffer in full-duplex mode
• 10/100/1000-Mbps Ethernet MAC with 1000BASE-X/SGMII 2XTBI PCS without FIFO buffer in full-duplex mode
So, SGMII is required for IEEE protocol.
