CNiclaes
1 year agoTriple-Speed Ethernet IP on Cyclone V GX - GXB Transceiver Reconfiguration
I'm integrating the Triple-Speed Ethernet IP on Cyclone V GX device (5CGXFC3B6F23I7) using Quartus Prime 23.1std. The generated IP has a reconfiguration interface made of two signals: reconfig_togxb...
Ash_R_Altera
1 year agoHi,
Are you still looking for answers on the topic that you posted? Anyway, I try to answer.
Dynamic Reconfiguration is required if you want to change certain features as mentioned in the following link:
7.1. Dynamic Reconfiguration Features
If not required the associated reconfig_<> signals can be either left unconnected or connect as per guideline in the description against each:
6.1.10.4. SERDES Control Signals
Hope this helps.
