SKon1
6 years agoTri-Speed Ethernet IP - Link Status up
Hello, I'm using the Tri-Speed Ethernet IP on an Arria V FPGA. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf The IP is configured as "PCS Only". Aft...
SengKok_L_Intel
6 years agoAre you saying led_an is high or led_link? If without any initialization, I don't think the led_an will be asserted.
Could you also read the value from "if_mode" register after reset/power on, this value should be 0?
Regards -SK
