SKon1
6 years agoTri-Speed Ethernet IP - Link Status up
Hello, I'm using the Tri-Speed Ethernet IP on an Arria V FPGA. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf The IP is configured as "PCS Only". Aft...
SKon1
6 years agoI checked it with signal tap - the led_an signal is high.
There's no connector to unplug - the FPGA is connected to the external device on a single board (via SGMII PCB traces - not over an Ethernet CAT cable).
