SKon1
6 years agoTri-Speed Ethernet IP - Link Status up
Hello, I'm using the Tri-Speed Ethernet IP on an Arria V FPGA. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf The IP is configured as "PCS Only". Aft...
SengKok_L_Intel
6 years agoHi,
There is a Link Synchronization block in the PCS, this block is to ensure CDR is stable and word alignment. Ethernet can achieve link if received 3 common characters (K28.5/D16.2).
To confirm if this is not the register at address 0x01 reporting the wrong info. It will be a great help if you can confirm the led link status signal. Besides, please unplug any connector to the TSE IP ethernet port to confirm if this can read out 0x89.
Regards -SK
