SKon1
6 years agoTri-Speed Ethernet IP - Link Status up
Hello, I'm using the Tri-Speed Ethernet IP on an Arria V FPGA. https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ethernet.pdf The IP is configured as "PCS Only". Aft...
SKon1
6 years agoThe Led Link status isn't connected to an actual LED so I'll have to check it using Signal Tap - I'll update on this.
What I can say now is that I consistently read out 0x8D after power-up WITHOUT INITIALIZING the IP. I don't do anything - just power up and I'm able to read 0x8D.
I was expecting 0x89 up to the point I initialize the IP over using the Avalon Bus...
