Transceiver Native PHY simulation error
- 6 years ago
For your information, the Native PHY can perform automatic word alignment if the RX word aligner mode is configured to “synchronous state machine”. I believe the example that you are having might be using manual alignment mode.
Sorry for the inconvenience.
Chee Pin
I have resend the file to your Forum registered email, using forum as well as using my company email. Please let me know if you still do not receive it. Thank you.
- Kavin6 years ago
Hi
Thanks.I received your email last week.With your help,i can simulate now,but i found rx_parallel_data is not the same as tx_parallel_data,is there any specifical rules i should follow? If 8B/10B coder is not applied, rx_parallel_data should be exactly the same as tx_parallel_data,is it right?
Kavin
- CheepinC_altera6 years ago
Thanks for your update. Regarding the parallel data mismatch, for your information, to ensure the parallel data is matching, you would need to perform the word alignment. Just wonder if you have had a chance to look into word alignment? Are you running the simulation with the example design which I shared or your own design currently?
Thank you.
- Kavin6 years ago
Hi
Thanks.I used to think that word alignment is done automatically by PHY. At your reminder, the simulation goes well after word alignment. Do all types of PHYs do not support automatic alignment, and does the actual design require internal logic for byte alignment?
