Transceiver Native PHY simulation error
- 6 years ago
For your information, the Native PHY can perform automatic word alignment if the RX word aligner mode is configured to “synchronous state machine”. I believe the example that you are having might be using manual alignment mode.
Sorry for the inconvenience.
Chee Pin
Please correct me if I am wrong, as I understand it, you configure your settings in Native PHY IP Parameter Editor and generate the HDL with simulation model. Then you go to the sim folder to compile and run the simulation. For your information, for the simulation to work, you will need to hook up additional IPs ie XCVR reset controller and the TX PLL.
I have a A10 Native PHY simulation example previously from wiki but it is running on Q15.1. You can refer to it and try to customize from there.
Thank you.
- Kavin6 years ago
Hi
Both XCVR reset controller and tx pll were added in my design.I can not find your simulation example, could you be kind enough to e_mail the example to me?
Kavin
