Tranceiver Enhanced PCS Basic mode questions
- 2 months ago
Hi MinzhiWang,
1) There is a Word Aligner block in Cyclone 10 GX, instead of Byte Ordering. Refer Table 29 in https://docs.altera.com/r/docs/683054/20.1/cyclone-10-gx-transceiver-phy-user-guide/standard-pcs-parameters.
2) Typically both Tx and Rx and connected to other side Rx and Tx respectively. Then, you send a know response. Else, use general purpose IOs to communicate the Rx readiness. This will be your own custom logic.
Hoep this clarifies.
Altera Tech Support
For 1) In a Cyclone 10 GX Transceiver Native PHY configured with:
- Transceiver configuration rules = Basic (Enhanced PCS)
- PMA configuration rules = Basic
the tx_control and rx_control ports are generally not exposed when “Enable simplified data interface” is ON. Even with the simplified interface OFF, those control ports only appear for PCS modes that actually use explicit per-byte control (e.g., 8b/10b streaming). Most Enhanced PCS profiles (often 64B/66B-based) handle control internally, so tx_control/rx_control do not appear at all.
Your observation— not seeing rx_control/tx_control when the simplified data interface is ON—is expected for Enhanced PCS configurations.
For 2) For the Basic or Custom mode, 2 LSB bits are used to identify data or control word.
Hope this helps.
- MinzhiWang5 months ago
Hi Ash,
Thanks for you reply.
You know we migrate from Arria GX to Cyclone 10 GX now. We used exactly per-byte control in our previous application when using Arria GX, however, the parallel data width was limited to 16-bit.
Now, we have chance to expand our parallel data bit width from 16-bit to 32-bit on Cyclone 10 GX devices. We still don't use any protocol, and transfer data from one point to another point. Just change parallel data bit width and increase the serial data rate. In this case, we chose to use Enhanced PCS, but how can we align word boundary in this case?
Best Regards
- Ash_R_Altera5 months ago
I would think of using either of the Enhanced PCS blocks
1) Rx block Synchronizer
2) Tx/RX bitslip ports under Gearbox parameters
Hi Ash,
You means that user do not need to send control code on transmit side?
