Tone Mapping Operator IP Malfunctioning
- 11 months ago
Hi @dscully David,
Does this IP have undocumented restrictions on input resolution?
>> Yes, there is restrictions on the input resolution.
For the input width, it needs to be multiple of the pixels in parallels (PIP) and the number of internal tiles (it is fixed as 4)- So, if PIP = 4 and Number of tiles = 4, then the width needs to be multiple of 4x4 = 16
- For the given two widths you could see that condition is not met, 1944/16 = 121.5 and 3268/16=204.25
- I suggest your to try: 1952 for the first case,
- and 3280 for the second case, then if need be, you could use a clipper to put the width back to your desired width.
- For the input height, it needs to be multiple of the number of internal tiles (it is fixed as 4)
- In this case, your current values are both fine.
Wincent_Altera
HI @dscully ,
Thanks for trying that, I just try to understand better
>> means by default it is working well (without black bar)
>> Am I get this correct ?
intel_vvp_tmo_set_roi_horizontal_x0x1(&tmo_instance, 200, 400) intel_vvp_tmo_set_roi_vertical_y0y1(&tmo_instance, 200, 400)
>> The things happen ONLY when you try to set the ROI ?
Wincent
Hi Wincent,
If I set the resolution with intel_vvp_tmo_set_resolution and then try to exit bypass mode the component stops producing frames. In ROI mode, the component still produces frames but shows the black box as described above.
David
- Wincent_Altera1 year ago
Hi @dscully David,
If you not perform that , you wont see the black box ? Am I get this correct ?
>> just try to understand why you not use the default setting but trying out this ?
>> Is that part of your project requirement ?
>> If I understand correctly from you, by default on VVP design this "black box" issue is not observed in 2k or 800x800 .
But once you make the change as your previous reply the black box came out , am I understand this correctly ?
Wincent- dscully1 year ago
Hi Wincent,
If I don't use ROI mode I don't see a black box. However, I expect in non-ROI mode for the component to function and not freeze the video pipeline when leaving bypass mode. I don't know what you mean by not using the "default settings". I am following the example from the documentation which clearly sets the resolution with intel_vvp_tmo_set_resolution:
By "default" this design does not perform its intended functionality regardless of resolution in ROI or non-ROI mode.
David
Hi @dscully David,
Thanks for the clarification, now I am clear about your situation.
Please allow me to have sometime to check on this, it might take sometime.
Will get back to you as soon as possible.
Regards,Wincent
