15 years agothe Transceiver IPcore in Stratix IV GX can't work well
hello, The transceiver can't locked the input port of pll_inclk,when i use the IPcore . the output port of pll_locked always be low. and the tx_dataout can't output at the correct rate. PS: p...
15 years agothanks Dave
yes,i have tried different data rate,1.6Gbps,2Gbps,4Gbps,5Gbps,8Gbps...sometimes it's all work well,but the result is not correct for most of times. for the reference clock,i'm sure it's good. i use Oscilloscope to test the clock,and it's displays well. the board is not custom board,it's made by ourselves,and we don't have any Altera reference board to compare .May be it's the problem of the board,but the pin Pins are connected correctly,and power supplies well. i will try the way of SignalTap II to test if all the control signal is right. i hope there is something wrong in my logic,but not the board.god bless... thanks for your advice best regards flzhnGlen
7 years agoHi,
Have you resolved this issue?
We just meet a similiar problem on stratix iv device. ALTGX is configured as transmitter only mode, but the CMU PLL is unlocked.
glen
