SPols
7 years agoThe DDR2 Controller with UniPHY has a port called "afi_reset". What causes this signal to assert? We are experiencing this signal asserting on a small subset of custom fpga boards. We are trying to debug the exact cause.
We have made a set of custom boards incorporating the Altera chip as documented in the information of the form. We have an issue directly related to the DDR2 controller on 2 of the 12 boards we have ...
NurAida_A_Intel
7 years agoDear Spols,
The reset pin is introduced for system stability. This Reset pin is an active-low signal and the main cause this reset pin asserted is due to the PLL lose lock.
And the PLL might lose lock due to a number of possible causes. As far as I know, two main reasons of that kind of behavioral is clock source quality and temperature in which device is working. I would suggest going through below check-list that may help.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/operation-and-testing/pll-and-clock-management/pll-loss-lock.html
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/support/devices/pll/pll-loss-of-lock-checklist.pdf
Hopefully this is helpful . 😊
NAli1
