yairShapira
5 years agoTES With SGMII interface - Unspecified errored packets.
Hi All. I have implemented two TSE with SGMII PCS On a cyclone V FPGA. each SGMII is connected to a PHY (MARVEL 88E1512). And the PHY's are connected to each other through RJ45 cable. I have a good...
- 5 years ago
Yes. Everything is fine now. I found out (after some try and error) that the packet length field should indicate the length of the payload + fcs field.
Thanks a lot for your help.
Best regards
Yair.
Deshi_Intel
5 years agoHi Yair,
Good to know. Yup, monitoring data_rx_erroris good idea to identify error type.
So, does it mean you issue is resolved now ?
Also, I found below TSE debug checklist guide that you can keep as reference as well.
dlim
- yairShapira5 years ago
Best regards
Yair.
